Please grade my homework, first off, thanks to those who responded to my request for info on the torque tube! This '53 project was rec'd in many different unlabled boxes. Todays box contained a orig, oil filter can w/ubolts and 2 new hoses with identical fittings(1 longer than the other)and a new stuffed sock behive shaped filter. I searched in vain thru the manuals for a clear pic of hose routing.After mounting the can on the intake manfld, I routed a hose from the bottom of same to the lower thrd port at base of block(left of center of manfld).The remaining hose went from the upper side to a thrd port right of center and about 11/2 in. higher. This port was a shared fitting w/a smaller orifice,which I assumed goes to the pressure ga.The filter was inserted round side up,(removal wire attached here) was 1st. tempted to install in the reverse. How'd I do for a guess job??? If y'all got any extra rain send it here,'cause we're hurtin!! God bless, fyrman
