Posts: 188 |
Just got through putting a rebuilt carb from Chevys of the 40's on my 54 powerglide. It starts fine and seems to take the fuel well except when you press down hard on the accelerator, then it spits back through the carb and sometimes even die. It doesn't do this unless you give it a lot of gas all of a sudden. The carb that was on it did the same thing. It was rebuilt and still the problem existed. After sinking the money into another carb, I still have a problem. Anyone got any ideas or suggestions? No one around here works on the old six cylinder anymore and all I get for advice are guesses. Could this be an advance problem with the distributor?
Read carefully my advice. With the main coil wire from the coil to the distributor disconnected. With a light source (not a flame) shining down the throat of the carburetor, make a quick movement with the throttle. If everything is functional, you should see a squirt of raw gas into the throat of the carburetor. This tells us if the accelerator pump is working. If you see the gas, your problem may be elsewhere. If you don't see the gas the carburetor must be disassembled and the accelerator pump checked for a problem, or the passageway may be plugged. If so, then return to the purchase source.
Posts: 570 |
I don't know about the advance part of it, but I would definatly check the distributer shaft play. If there is excessive play, it will cause your points to "float" and thus the miss/backfire. I would also check your points for proper gap, and sparkplugs for proper heat range, look for blisters.
Bud, You know that it takes those engines about 20 minutes to warm up.May be your expecting too much.Is the heat riser free?Try advancing the timing a little more. If you don't see gas squirting in forget the above.
Posts: 176 |
Check the base of the carb at the intake manifold. There should not be a gasket at this point. The insulator block is all that goes at that location. Using a gasket cuts off the vaccuum to the distributor advance and thus causing the problem that you indicate. I have seen this on three 53, 54 chevys in the last couple of months.
Walt D 1934 Mstr 4 dr/sidemnts 1937 1/2 ton P/U 1953 Bel Air HT 1946 Aeronca 7-AC Champ
Will also cut of the vacuum to the vacuum operated power piston in the carburetor.This will place the piston in the full power or rich position at all times.The little hole under the base of the carburetor must line up with a notch in the insulator.
