The cover on the rear of the shifter cover , covers a shaft with 2 levers, and a shaft that slides backwards and forwards . The shaft has a slot in it, and the two short levers have a pin, that appears to be either hardened or chrome plated for wear resistance. The rear shaft is what connects to the vacuum cylinder, and changes the gearing in the gearbox, R to 1st, and 2nd to third. The front lever on the shifter cover , changes the shifting from R to First, to the 2nd to third position. If you remove the cover, I do not see why you could not tap and thread the holes , and replace with screws and star washers .
