Thread Like Summary
Clement
Total Likes: 2
#488271 01/01/2024 8:35 PM
by hdbob5454
hdbob5454
recently got a 52 fleetline and started to try to get it running took off glass bowl cleaning it and the screen out , put it back together and can't stop it from leaking gasket looking ok but even after flipping it over it still leaks . Is there a place that sells replacement gaskets or do you use something else like something from a hardware store ? thanks
Liked Replies
#488276 Jan 1st a 10:09 PM
by Chev Nut
Chev Nut
If it is the glass bowl on the fuel pump you can get a new gasket for the FiLLing Station.
If it is a add on gas filter you will have to now the brand etc. and tha could be a problem.
If you were to make a gasket it must be of a gas resistant material.
The orginal fuel pump gaaket was cork but chnge to neoprene rubber years ago.
Are you sure it is the gasket leaking?
1 member likes this
#488285 Jan 2nd a 01:55 AM
by 35Mike
35Mike
It is not unlikely that the mounting surface for the bowl is warped. This is a result of over tightening.
Fel pro makes several sizes of bowl gaskets that are probably stocked at a local auto parts store. Other gasket companies probably offer them as well. Take the bowl with you to the store.
A new gasket will not solve your problem if the pump surface is badly warped. It might have been sealed by gunk, before you removed it.
1 member likes this
