Hello all,
I wanted to share a short video of my `30 coupe after its been sitting since last winter with the carb removed for rebuilding.
I finally got the carb rebuilt, did a tune up, and a valve adjustment. I put the wire wheels on (still need to decide on a color) and started to drive it on short shake down trips.
Found I had a few bent push rods (you can just heard them tap on the push rod/lifter cover) and my rocker arm shaft is worn. Getting those items ironed out and continue with the shake down runs.
Kind regards,
Randy
