I brought home my newly acquired '35 Coupe this past weekend. The engine was lightly stuck but moved quickly with a pry bar in the starter ring gear teeth. After new plugs, points, condenser, changed coil and carb, and finally the starter, it starts and runs for a few seconds and dies. On a couple of occasions it has run for as much as 1/2 minute. At first, it surged for the time it was running. That has gone away and it seems to run smooth, but will not rev up. It acts like it is struggling to keep running, then dies. Timing has been checked and reset. Vacuum advance holds vacuum. The replacement carb came from my, perfectly running, other, '35 Standard coupe. Any ideas??
