Thread Like Summary
jack39rdstr
Total Likes: 1
#484585 08/21/2023 11:33 PM
by pgbaresel
pgbaresel
How do you repack the water pump on my 1928 Chevy? Are there special tools to purchase and remove/install the packing? thanks for your input.
Liked Replies
#484763 Aug 27th a 12:53 PM
by pgbaresel
pgbaresel
I was able to clean out all of the old packing in the packing nut with a small dental tool. I also took fine emery cloth to clean up the the water pump shaft and install the packing. I did not use the graphite rope packing as no one in the hardware store knew that the packing was used on old faucet handles to keep them from leaking.
I did brush in some white lithium grease inside the packing nut which made the packing slide into the nut without breaking it. The truck did not over heat with a half hour test drive!
I did not know about air being sucked into the radiator through bad water pump packing.
I am learning a lot from the forum.
1 member likes this
