Thread Like Summary
Rookie_Wrench
Total Likes: 4
#482983 06/26/2023 10:41 PM
by Rookie_Wrench
Rookie_Wrench
First of many dumb questions! If my 49 Chevy Styleline Deluxe is running and I pull the positive battery cable lead, shouldn't the car keep running with the generator? If it dies ( and my car did) it confirms a bad generator?
I have a cheap multimeter, but really dont know how to use it, which is why I am asking, but if I could be directed to how to use it maybe I can do that?
If I place the lead of the skinny wire post on generator and touch the block to ground or is it the thicker wire and the other to ground while car is running?
Liked Replies
#482988 Jun 27th a 02:16 AM
by Jonjet
Jonjet
It should run if the RPMs are up.
1 member likes this
#482991 Jun 27th a 10:32 AM
by tonyw
tonyw
As Jon suggested at low engine speed generators dont have a large output but at light throttle opening should put about 7.2 volts (for a 6v battery or 13.8v for 12v) at the battery or generator output terminal.
1 member likes this
#482994 Jun 27th a 01:41 PM
by Mr87Monty
Mr87Monty
I have a 6v 41 Master Deluxe. The charge gauge will drop slightly below the mid point during idle. With the lights and / or fog lights are on this is more noticeable. This is an indication that at idle the generator is producing less than is required and the car is discharging the battery. As soon as the RPMs are increased the needle moves above the mid point and then back to the mid point. This indicates that it is charging, when it returns to the midpoint the battery is charged.
I would avoid removing the battery cable while running. It is best to avoid sparks or any potential shorts. Touching a potentially live positive cable to the chasse would not be good.
1 member likes this
#482995 Jun 27th a 02:02 PM
by TiredOil
TiredOil
You can use the multimeter direct on the battery (multimeter red wire to battery + and black wire to battery -). Measure it at idle and higher rpm too.
Mihaly
1 member likes this
