I am working on restoring a 47 Chevy convertible and I am still having problems with my vacuum wipers. I pulled the vacuum wiper motor and cleaned and lubed it and ran it directly from the manifold and it seemed to work correctly. There was not a vacuum leak from the motor. When I reinstalled the motor, I hear a vacuum leak from under the dash and the wipers do not run correctly. I replaced all the vacuum hoses with new hoses of the correct size. I am thinking there is a problem with the switch leaking. Is there any recommendations on cleaning or repairing the wiper switch? Thanks for your help.
