I have weird question, I had to get a different block for my 41 Master Deluxe and I picked up a 1948 216 motor to use as a doner. So I am trying get bearings.010 over and they seem to be hard to get for a 1948-53, but 1941-47 are readily available.
Does anyone know the difference between these 216 blocks that makes the mains different. The rod bearings are the same for both date ranges so I was just curious. I have a good 41 crank that I can use If needed.
I have access to a machine shop and can do modifications if necessary
