I've ALWAYS had ethylene glycol antifreeze in my '29 and never had a problem. I know others have, but not me. The article says the problem is due to, and can be cured with the water pump. That implies that if you have a packing style pump in very good condition, you shouldn't have a problem either.
I live in Canada, but I know that it DOES freeze as far south as Florida and Texas. Experience here has shown that even the SLIGHTEST frost can and will severely crack a block or head. In fact, for some reason, more engines seemed to suffer cracks when there was 1 degree of frost, than when there was 4 or 5 degrees of frost. Some thought that it was because the 1 degree frosts often lasted for hours and had more time for the ice to expand, which did more damage than a sudden but short 4 or 5 degrees.
Long story short, I NEVER trust leaving water without antifreeze in any engine.
