Thread Like Summary
Jrlaplante
Total Likes: 1
#476876 12/13/2022 10:44 PM
by Jrlaplante
Jrlaplante
Trying to get the nut screw loose on the shocks on my 33 master. Have tried a little heat(propane torch) but don't want to cook anything inside. These things are stuck like they are welded on. Any suggestions and or experience removing these? Thanks
Liked Replies
#476887 Dec 14th a 03:08 PM
by Dave39MD
Dave39MD
Good advice on the heating and cooling. My shock plug would not come out and I did the heating, cooling, pb blaster cycle. I ended up using a heavy screw drive bit in my long handled socket and it came loose. It is the heavy bit I use on tie rod ends.
Good luck!
1 member likes this
