Welcome to the VCCA's website!
I never noticed the dot in the middle of the bowtie before your post. ;-)
The engine (block) number that Steelin_Time mentioned is stamped into the flat boss above the casting date.
As he mentioned, if the number is preceded with a T, it was a truck block. If the number was preceded with an X, it was meant for export. I think the blocks put into cars had no letter preceding the engine number. There are other letters that mean other things, but I don't know what they are.
The number itself indicates the block's number in the sequence of ALL the four cylinder blocks made. I believe the total number was around 5.3 million!
The block that I used in my rebuild in 2017 has the dot in the bowtie, but I don't know what the block number is because I didn't look at it before putting the side covers on. ;-(
At the bottom of this post is a photo of that block before it was cleaned up. You can see the dot in the bowtie, but there's too much rust on the engine number boss to see the number.
I did find a photo of an engine block with the dot that has an X preceding the block number. That photo is below also. That photo came from this thread:
1928 Truck PuzzleIf you are interested in my engine rebuild adventure, it is documented here:
Resurrecting a '28 4 BangerCheers, Dean
![[Linked Image from vccachat.org]](https://vccachat.org/gallery/48/full/4863.jpg)
