Working my way through all existing concerns still on the 31 Independence. Want it road ready for Spring.
The gas pedal rod connects directly to the carb assembly with a return spring connected to the manifold. Pedal does not return fully when foot pressure is released. Need slip my foot under the accelerator button to slow the engine down. I have purchased a replacement spring but wonder if additionally there is adjustment I could render to tighten the assembly up? Too dangerous to drive as is. Difficult to see that area in that it is the back side of the carb wedged against the engine block.
