Hello, I need to replace my motor mounts and it appears my engine is still leaking a bit of oil. So while i have the engine unbolted from the frame and raised a bit I figured it would be a good time to change the oil pan gasket. All I can tell is the oil pan is wet, I have replaced the valve cover and side cover gaskets. Can anyone tell me...
1) can the oil pan gasket be replaced with the engine in the car?
2) can the rear main seal be replaced at this time also?
I am not sure if the pan will come out, I am not sure how the bottom end looks on the 216.
Thank you
