This is the type of sender I was referring to. The main shaft has to be adjusted as short as it'll go to not bottom out on the tank. That leaves the problem that the float arm must be very short so to not bottom out on the tank which lead to the issues I mentioned.
https://store.fillingstation.com/de...UNIVERSAL_FUEL_SENDING_UNIT_030_OHM.html
