Update, I opened the shift box and found it packed with grease as thick as black strap molasses on a cold January day! Oh wait a minute, it is January! I believe that the grease was too thick and was not allowing the spring in the shift box to function properly. It was a cold day when I went for a ride, possibly the coldest I’ve had the car out in. Also the screws had worked loose on the upper support collar. I’ve not had an opportunity to go for a test ride yet, but just working the lever through the shift pattern seems to be doing as it is supposed to. Shift pivot is lubed , too.
