If a specific post was interesting or useful to you, we recommend that you Like that post. It tells the post author, and others, that you found the information valuable. Clicking Like is another way to let others know that you enjoy it without leaving a comment.
Log in to join the conversation and Like this content.
Well..... I started to work on changing out the front cross member. Being an old man I work a lot slower, seems things are much heavier than they used to be. Removed the hood and made a buck for it, so that it should not get damaged. Next removed the radiator. Had to get the water pump out of the way. There isn't alot of space between the radiator and the water pump. Making progress, but the 1939 will have to wait a little. The 1924 Model T is acting up and needs some attention. Maybe this week end I can get a few more items removed. I called the Filling Station to find out about getting the front shock absorbers rebuilt. Mike
