Yes, you've got it.
One other thing.
I was having a little trouble getting the end pieces to stay on the bearing caps...
until I realized I didn't have the cork truly seated in the grooves and had to get the edges toward the outer ends of the bearing caps
(front edge on the front bearing, back edge on the back bearing) in tight to the cap first,
then wedge/compress the cork into the groove until the remaining edges snapped past the edge of the groove in the bearing cap.
Then they stayed solidly in place while I installed the pan.
PS
In the gasket set I used (from The Filling Station) the end pieces were a tight fit width wise in the grooves,
but once they were in there, they were in there!
It was a great gasket set in my opinion.
