I didn't change any gas lines. I disconnected the gas line at the tank and the fuel pump. I blew out the line and then put in about 12 pounds of pressure. After a half an hour, there was still over 10 pounds of pressure in the line. I followed the line and no place where it could get hot. I let it run a bit and felt the back of the ignition switch. Not burning hot but very hot after a few minutes running. A replacement switch is ordered. Thanks CHIPPER and everyone else. I will let you know when the ignition switch gets here and installed.
