Took the valve cover off to fix a leaking valve cover gasket and found that the oil line to the rocker oiler was cut and that the return line was held on with a piece of wire. The old gasket was cracked at each corner and extremely hard. Thanks to the community at VCCA we were able to replace the part. My oldest took off the front set of rockers so we could slide the new oiler on. Using a compression fitting the old line could be attached to the new oiler. Once the rockers were all back in place we checked the spacing and verified that oil was going everywhere it was supposed to. Next we put a valve cover gasket on and gave it a test drive. No leaks appeared from the valve cover gasket and the engine sounds better since setting the spacing on the valves. Since we were doing all this work we changed the spark plugs also. They did not look bad but we had it apart.
