That pan looks way better than the one was on my car. I measured 5/8" of sludge in the bottom. The oil pump inlet screen was completely coated.
I cleaned everything up, checked the oil pump, and adjusted the crank and rod bearings by removing shims. I also cleaned the pressure valve on the left side of the engine, removed and cleaned the rocker arm assemblies, and made sure the oil feed to the rocker arms was open.
The engine ran great. I put about 6500 miles on it in 5 years with no problems.
