The picture you provided of fuel pump cover shows that you have the aftermarket or later style cover with pressed in check valves. The original AC fuel pumps had a leaf spring or retainer with 1 or 2 screws that held the check valves in place with gaskets. If the fuel pump kit you purchased has original size outside diameter check valves, then the new check valves will probably fall into the holes as the later pressed in check valves are slightly larger in outside diameter. To get these pressed in check valve out, I use a small slide hammer with a special end that threads into the center of the check valve once the cross bars are broken out.
Mike is a great fellow and if he is willing to send you an original fuel pump, I would go for it.
I rebuild fuel pumps and this is what they look like when I get done with one. See attached pictures.
