If a specific post was interesting or useful to you, we recommend that you Like that post. It tells the post author, and others, that you found the information valuable. Clicking Like is another way to let others know that you enjoy it without leaving a comment.
Log in to join the conversation and Like this content.
Winter break is over and we have completed rewiring the car. All of the new items function properly. The dimmer for the dash lights now works. Car now has blinkers and a horn. All of the dash lights were replaced with new bulbs. Started the car and drove it out into the driveway to test everything. The headlights, dash lights and especially the tail lights all appeared brighter after the rewiring. After this was completed we documented all of the new wire colors in the back of the 41 service manual. Also recorded the part numbers for the blinker kit and the flasher.
The chassis was lubricated today. First time they have used a grease gun. Found a diagram in the 41 maintenance manual showing all of the lubrication points. While they were working down there they adjusted the hangar for the tailpipe. It was too high in the rear and the pipe did not allow for much movement. Loosening the mount a little and lengthening it gave the pipe some give and allowed it to hang closer to the correct position.
We made an effort to get the radio working for the car. Using jumper wires with alligator clips on them we connected them to the car. Also connected an antenna. With the power on to the car we turned the dial on the radio to see what would happen. Then we waited hoping it just needed to warm up. Then we tuned it hoping something would happen. Finally we decided that since only one tube had a slight glow to it that the radio was not going to work without requiring repairs. We had already decided if it worked currently then we would put it in. If it did not then we were going to let it be. There are only a few talk radio AM channels left in the area and of these only two are powerful enough to receive regularly so there is not much benefit to us from an AM only radio unless it already worked. Going to go with a hidden Bluetooth speaker when we get to that point. Might still clean up the old radio and place it in the dash for looks. That is a decision for another time.
