. Remove the 4 bolts and separate the U-joint. First, Place some bailing wire behind the portion of U-joint attached to the trans to hold it in place. Slide the rear half of the U-joint yoke on the propeller shaft. Align with front half of U-joint. Bolt U-joint together. Remove bailing wire. Slide bell back in trans and bolt in place. If you forgot the Bell gasket, split it at top and use gasket cement.
Good luck, Lou .
