Well, it wasn't fixed as good as I thought. Started it up the other day and BAM right to 212! I played with it a bit and said done and left it. I had run some radiator flush/cleaner through it which didn't do anything. Got too frustrated and didn't want to do something stupid and screw it up more. Tossed and turned for 2 nights wondering what it could be and dreading that it was the head gasket. I decided I was going to get it fixed today no matter what. I took off all the hoses and took out the thermostat. I started by filling the radiator with water. It was draining VERY slowly. I was expecting it to be free flowing considering that I had already flushed and back flushed it the other day. Obviously, a blockage. I blocked the upper hose connection an put the garden hose on full and backflushed it again. Water came out the top of the radiator but not at any great rate. The cap from the antifreeze container fits perfectly over the bottom radiator hose nipple. I drilled a hole in the cap and put it on. I took my compressor and blew air from the bottom to the top of the radiator. Water went everywhere. I filled it back up and the water came through the hole in the cap like a slow running water fountain. I filled it again and blew it out again and the rusty water came out somewhat stronger. Making progress. I did it a few more times and by the end the water was spewing out of the hole in the cap out of the engine compartment onto the front fender and no rusty water. I guess the radiator is free and clear. I flushed the heater and the block until all ran clear. I put everything back together and filled with water. I started the car and instead of overheating in 10 minutes, it took 40 minutes to get to 180. I let it run for over an hour and it never passed 180. WHOOPIE! I examined some of the crap that came out of the radiator when I backflushed it and it seemed to be soft fibrous material. I also noticed when I shut the car off, the water pump was leaking out of the shaft. Putting 2 and 2 together I figured the stuff that was in the radiator was the packing for the pump. Didn't know the packing would come apart and go into the radiator. So when I repack the pump, I should be all set to go. Just a coincidence that the packing came apart and blocked the radiator the same day that I tweaked the distributor. Chased my tail for a week but finally done. Thanks all for all the tips and advice. Pete V
