IT WOULD BE NORMAL WITH COLD OIL. WITH HOT OIL AT IDLE 2 TO 3 POUNDS UNLESS THE VANE OIL PUMP HAS BEEN REPLACED WITH A GEAR TYPE PUMP. THEN WILL BE A FEW POUNDS HIGHER.
With the original vane type pump, the hot oil pressure will be around 7 to 10 pounds at road speeds.
