When you do decide to fix it correctly, one possibility is to disconnect the wire that runs up the steering column from the horn, remove the terminal, and slide a long piece of heat-shrink tubing over the wire and right up the steering column to the bushing to insulate the wire from the steering shaft and the housing. Then reterminate the wire and reattach to the horn.
All the Best.
Chip
