After a piston was in the cylinder, I turned the block 90 degrees and was able to pull the connecting rod by hand down to meet the crankshaft. Then, I put the rod cap on and tightened the nuts.
I don't think tightening the rod caps added to the friction of turning the crank, but they also do not seem loose around the crank. So I am going to leave them alone for now. After I run the engine a little and it loosens up, I'll drop the oil pan and adjust the rod caps so that they are gapped correctly.
Since I don't have the head on yet and I want to keep the cylinders clean, I cut a piece of sheet aluminum to cover the cylinders and used the old head gasket to hold the sheet down. Then, I used a bunch of the 1/2-12 short head bolts (with washers and a pipe spacer) to clamp the lid on the top of the block.
The reason for my concern about cleanliness? Check out the bottom photo. This is the work space that I'm building the engine in. Yes, I have 10 pounds of stuff in a five pound bag. There's no place like home!
