Dave41 Offline OP
Does anyone know how to pull these apart to install them?
1935 Mst Roadster,1939 Norton Big 4 outfit, 1942 Buick, 1943 GPW,1959 Bel Air 2 Dr, 1963 Corvair Convert. 1956 FJ Holden Ute
Hooroo from OZ
Support The VCCA!
Hi,
The first step is to disassemble the switch and remove the wire that goes through the handle from the switch. Next is to remove the through bolt just at the end of the grip/handle. With this bolt removed you can pull the handle off. Now the light and long shaft can be inserted in the hole from the outside of the car, replace the handle and through bolt and finally reconnect the switch wire.
Agrin
