Posts: 1,281 |
DID CHEVROLET CHANGE THE STARTING CRANKS EVERY YEAR OR WERE SOME FOR MULTIPLE YEARS?? :confused: :confused:  :confused: :confused:
Posts: 1,281 |
SKIP, NOW THAT IS A VERY INTERESTING NOTE, YOU SAY THE 31 32 CRANKS HAD A ROTATING HANDLE? DID OTHER YEARS ALSO HAVE THAT ROTATING HANDLE?????? :) :)  :) :)
Posts: 1,281 |
AS I UNDERSTAND IT, YOU SAY THE 31 AND 32 STARTING CRANK IS 18 AND ONE HALF INCHES LONG AND THE END YOU HOLD ON TO ROTATES????? :) :)  :) :)
Posts: 1,281 |
Posts: 11,162 |
No! No! Donald that device on my ranch ( the Oleo Ponderosa) is a cattle guard it is for keeping the cows from going out the road where Yankees usually have a wire gap or gate. a carttle guard is a hole down in the ground all the way across the road and about 5 feet wide and three feet deep, 3 inch pipe is laid across the hole from one side to the other side and the pipes are about 4 inches apart, and you can drive across the hole on the pipes, but a dumb old cow is afraid to cross it, their feet fall down between the pipes. so they won't even try, us lazy drivers can zip right across with gaving to stop and open a gate! Neat Hunh!
Posts: 11,162 |
Oh! I forgot. How far from the tip of the 32 crank is it to the cross pin ( Not a Cross Pen) Ha! I hear is a different distance than on a Model "A" crank, I am going to build some cranksout of sucker rods and drill rod and 3/4 inch sockets for to sell at the swap meet and I want them to be authenic, like Rays and JYDs
PS also, how far does the cross pins stick out from the side of the crank, and what diameter pin do I need to use, I am going to drill a hole out cross ways on the crank end, that goes in the engine and weld or braze the pin in sos it don't fall out.
pps You better get your order in, I only have enough sucker rods to make about 125 cranks, I already bought some 3/4 inch sockets at a junk store.
Posts: 11,162 |
Oh yeah, I know what a cow catcher is, it is a big old glove like a catcher wears but to catch cow chips with when you play "Catch the cow-chip" right? I also saw one on an old steam locomotive, but that is another story. Right? Ps On the El cheep-O sockets, I only use the best junk money can buy, and at the prices I plan to charge for my valuable time, quality work etc. I can use real good junk, tell Donald not to worry!
Macky, Up in Canada for the 4-banger tour we saw several signs along the side of the road for a "Texas Gate". When we went a little further we went over a cattle guard. Guess they understand where they came from.
Dog-face has it right. 3/4" dia. rod, 18 1/2" long with 5/16" cross pin at 1/2" from the end. The pin is swagged into a hole in the big rod not welded or brazed. Picked up some stock from the salvage yesterday to make a few for ole Donnie. He won't know that they are not genuine. The roller handle is a bit more tricky. It is a secret how to make that easily. It is also better if you put the groove in the rod on the lathe before bending. Yes, the groove is in there to hold the roller handle.
Better get some other sockets though. All of the cheap cino crap sockets are 12 point and the one on the crank is 6 point. Too much trouble to weld up the extra slots. Maybe Donnie will not notice.
I thought a cowcatcher was a cowboy on a horse holding a rope
Nope.........that's a drover! :eek: :eek: Hey Macky Wacky: Don't worry about if the socket has 12 points or 6 points........old Donald knows nothin' about points anyway (except for judging), so he will never know the difference. On the rolled handle that Chip The Dip was talking about, there is an easy way to do that for old Donny. Just take a starting crank with the socket end. Cut a hole in an old tennis ball. Slide the tennis ball over the socket end, and there ya have it. I rotating handle for old Donny. Again, he won't understand it anyway, so it should work great for him!  :p
Posts: 1,281 |
WOW, IF THERES ONE THING THAT I WOULD NEVER HAVE, ITS A STARTING CRANK WITH A SOCKET ON ONE END?WHY THEY NEVER HAD SUCH A ANIMAL FOR 32, EXCEPT FOR THE THE CARS THAT WERE SHIPPED TO THE FOREIGN LEGION. YOU DUDES HAD BETTER READ YOUR DOCUMENTATION ABOUT STARTING CRANKS WITH SOCKETS FOR 1932 CHEVYS, WHERE IN THE HECK DID YOU DUDES EVER GET INFORMATION LIKE THAT??? WHO HAS DOCUMENTATION THAT THE CRANKS HAD A HANDLE THAT TURNED ON ONE END, I THOUGHT ONLY MODEL TS AND AS HAD THEM. :arrow: :arrow: :arrow: :arrow:
Posts: 1,281 |
OH NO, YOU GUYS WERE TALKING TO THAT DONALD GUY, MY NAME IS 32 STARTING CRANK WITHOUT A SOCKET. GEE, YOU DUDES SHOULD KNOW THAT. :arrow: :arrow: :arrow: :arrow:
Probably should wind this one up in the next few hours. It appears to have run it's course.
Posts: 1,281 |
Posts: 11,162 |
Chipper the way I do the rotating sleeve is to cut a "V shaped groove inside the handle end about 5.250 inches and then put a piece of metal conduit ( 5.750 inches long )with the outside end cupped to keep it from slideing into the bend of the handle then, slide the sleeve over the handle and I use an old dull rigid pipe cutter to press a groove in the conduit down into the groove cut into the handle, this keeps the sleeve from falling off the handle and saves your hand from banging the cow catcher.
Oh! Oh! I think I did a boo-boo and gave away a valuable trade secret.........
Posts: 11,162 |
Right, JYD, I meant when the sleeve slipped off the cranking handle (from not being properly crimped into the groove), you could bang your hand on the cowcatcher!
Posts: 11,162 |
Did you say that the 35 chevy crank was 33.1250 inches from the engine end to the first 105* bend, how long was the stroke of the crank? looks like one would need a bushing on the bumper to keep the alignment correct and not damage the radiator.
Posts: 1,281 |
I WONDER IF THE EARLY STARTING CRANKS HAD THE ROTATING HANDLES LIKE THE 31 AND 32 STARTING CRANKS. ALSO WERE THE FOUR CYLINDER CRANKS ALL THE SAME LENGTH???? :confused: :confused:  :confused: :confused:
From about 1918 to 1928 the starting cranks were the same length. In 1928 lengthened the crank to reach the engine. Worked on the '29 and '30s also. Then back to the shorter crank until '34. The earlier 4 cylinders had a two or three piece crank. Not sure about early 6 and 8s yet.
