I have a 1939 one and a half ton dually pickup truck like the one that Jim Carter has on his website (oldchevytrucks.com)(look under the working trucks section) and I am in need of a pair of rear fenders for this bed. They will fit '37-'46 chevy dually pickups and panel trucks. If anyone has any information on parts for this bed or has information on it, please let me know. Thanks
1939 Chevy 1 1/2 ton dually rear wheel pickup
1940 Chevy 1 1/2 ton single rear wheel pickup
1946 Chevy 2 ton cab and chassis
1977 Chevy 3/4 ton camper special 4x4
Obsessed 16yr old Chevy truck nut
Bob, Just a note-the pick-up fenders are not the same as a panel.The P.U are much deeper (or wider) than the panel.
Are you talking about dually fenders? I have heard from Jim Carter that single rear wheel fenders are the same on panels and pickups.
The parts book lists rear fenders as follows for 1939 1 1/2 ton.
Series VB -which is a dual wheel pick-up #350985-96
VB-panel with duals part #350779-80
VA-pick-up or panel with single wheels #599121-22
Ok, so dually rear fenders are different between panels and pickups but single rears are the same I take it.
If they are similar to the 1934 to 36 trucks the pickup fenders attach through holes in the inside edge of the fender, 1937-38 p/n 594855 & 856 (chassis & cab); the panels bolted up through holes in the top center line of the fender and the inner portion of the fender area was cut out, 1937-38 p/n 594181 & 182(except chassis & cab).
1939 rear pickup fender p/n 599295 &296 (chassis & cab); panel single unit bodies p/n 599121 & 122.
