#54080 11/10/03 03:33 PM
I am restoring a 1927 1 ton truck engine.
The crankshaft journals have been cleaned up. All of the babbitt bearings are in good shape but I noticed that one of the rod bearings has a hairline crack going between the oil journals, about 1/4". It is only in the babbitt material and does not go all the way to the edges. Do you think it would be acceptable to use?
scott walker
#54081 11/10/03 09:42 PM
Hi Scott,
Assuming all the other characteristics are within specifications the rod can be re-used with complete confidence.
You may find it interesting to go browse around HERE.
Agrin
#54082 11/11/03 03:43 PM
Thanks for the speedy response on re-using the cracked bearing. I read thru the posting you suggested on 'here' and it was very informative. I have had a local machine shop bore out the cylinders and purchased pistons from Egge. The machine shop cleaned up the crank. I had a spare rod to use just in case--but the babbitt bearing is not tight against the rod cap and was not sure if that would be acceptable or worse than using a bearing that is cracked. Is there a way of tightening down the bearing to the cap?
scott walker
#54083 11/11/03 04:59 PM
No, I would not recommend that. It should be repored as there is no way to insure a consistent clearance.
Agrin
