I have used this method on many steeringbox and with
great success
[Linked Image from img112.imageshack.us]
[Linked Image from img333.imageshack.us]
[Linked Image from img312.imageshack.us]
You can now adjust the gear/worm play with the bronze bushing.You most have a little play in the bottom bushings, and this play are already there. :)
From Norway
Arvid
http://www.chevroletnorge.com
Find the point when you have "no play" and have this point when you driving straight forward.
Arvid
Great Arvid,
and good pictures, I'll keep these for future reference.
Stil going slow ISP :(
Richard
How sweet is the roar of a Chevy four (Thanks Chipper)
Most Excellent. cool
Arvid,
What a good idea, and thanks for the excellent photos.
We have Dodge Fours with similar problems and will investigate if a similar modification can be done to them also.
Cheers,
Geoff
Hi Arvid,
A great idea for making an eccentric bush for the top of the steering box,but how do go about doing the same process to compensate for wear at the end of the shaft,where the plug screws into the bottom of the steering box?
:confused:
CJP'S 29
Hello Geoff and CJP'S 29.
Nice to hear from you down under, and hear you like the modification on the steering box.
I have made a eccentric bushing in the bottom one time, but I find it not necessary.It works great only with the bushing on the top.
[Linked Image from img98.imageshack.us]
I was in Brisbane and Sidney 2002-2003 and see the fireworks on the bridge in Sidney new-year.
It was a great experience.
I like to come back one time, but 20 hour's on the plane is a long time.
Summer and sun in Norway.
Regards Arvid
