Finally after struggling for several hours I was able to start it. But it runs pretty rough after sitting outdoors for a year without any activity. Maybe it’s ok due to the circumstances.
But it seems that it’s still out of adjustment.
The problem that I have is:
Starts perfectly with a the first turn (after warning up for a few minutes; I still use pyroil fluid when cold). Runs 10-20 seconds smoothly but on high revs after that stumbles and begins misfire erratically… but it won’t stall even when sounds like only one stroke operates. Spark plugs foul. Black dry soot. After deep cleaning of the spark plugs , does the same thing over and over again. Black smoke from tailpipe. Seems to be running little better with air cleaner/exhaust manifold detached from the carburetor. Starts without choke better.
Any ideas? Carburetor? Vacuum canister? Timing?
