. I've run into this problem a few times and resolved it in a different manner. Please read <
http://home.znet.com/r1937/WPump.htm>. . You can purchase the ready made adapter plates at Jim Carter's Truck parts, <sales@oldchevytrucks.com>, 800-842-1913, Part number #MEE390.
. The 1954 water pump has better flow and designed for non pressure system. The 1955 & newer used pressure. If you pressurize an old radiator and heater core, that's pressing your luck. You can also use the stock fan belt and not have to search for a special size belt. . Lou .
