Posts: 2 |
I would like to put 2" dropped spindles on the front of my 39 Chevy Master 85 sedan, the previous owner added front disc brakes, and later model spindles but I don't know the year, is there a number on the spindles that would identify the year ? I see spindles listed as 1964-1974 online
Posts: 3,487 Likes: 45
Posts: 3,487 Likes: 45 |
Your best bet is to determine who supplied the disc brake kit and the spindles. Even though there might be a casting or forging number on the spindle the same raw part can be made into many different machined parts.
The safest and simplest approach would be to buy a compete dropped spindle and disc brake set-up from a reputable hot rod supplier. If you mix and match parts any problems are yours to solve.
A riskier approach would be to make the needed conversion parts and mount the axle above the front leaf springs. There are a lot of unknowns and potential problems such as steering geometry in this solution.
Posts: 5,980 Likes: 22
ChatMaster - 5,000
ChatMaster - 5,000
Posts: 5,980 Likes: 22 |
I would be locating a dropped spindle and brake conversion kit from the same supplier that way everything is made to fit together easily. I would not be mounting the springs under the axle as there will not be any location items which will cause worse steering issues than the dropped spindles will cause. Tony
2 members (dunfire, Tiny),
181
guests, and
21
robots. |
Key:
Admin,
Global Mod,
Mod
Topics57,943
Posts422,318
Members17,888
