Aeroman Offline OP
Folks, I installed a NOS 1947 1948 6-Volt clock. I'm running 12-Volts in the car. I used the fuel gauge transistor voltage reducer (the one with the little pigtail for ground) but nothing happened. Clock wasn't working. Do you guys know which voltage reducer I should use? Thanks in advance.
Support The VCCA!
First test the clock on a 6V battery. Rotate the clock while connected to see if it ticks. Use synthetic clock oil to lubricate if it stops. You can get this oil in a long pen like tube with a very fine needle applicator. Place clock on bench at the same vertical position it is mounted in the car. The coil contacts can be tarnished from age. Clean with one drop of silver cleaner applied with paint brush. Remove cleaner drop with paper towel. If your fuel gauge works so should the clock. The clock should run for a few minutes on one charge of the spring.
Isn't the 47/48 clock a windup clock with electric used for the light in it?? Did Chev make an electric clock as an accesary?
Dick
They were both available as an accessory. Page 16 in my accessories booklet.
http://chevy.oldcarmanualproject.com/chevyresto/4709.htm
Russell #38868
'48 4 door Fleetline
First you need to determine which model clock you have. If there is only one wire I expect it is a wind-up clock. The wire is for the light.
If it is an electric clock, you will need to do some research to determine what size resistor you need so you get 6 volts to the clock motor. The resistor must have the same resistance as the clock motor so it takes half of the power and voltage.
A fuel gauge resistor might not be the correct choice. It might be the wrong resistance plus it might not be able to handle the amperage that the clock motor requires. The fuel gauge circuit does not draw much current.
Member Photos
My Beautiful 35
My Beautiful 35
by Lorenzo, March 26
1948 woodie
1948 woodie
by firecars, March 7
1918 D5 V8 pictures
1918 D5 V8 pictures
by Mel1940, November 18
Progression on the 64 Impala SS 409
by DreamChevy, October 21
Who's Online Now
6 members (BearsFan315, Chipper, Mike McCagh, ruscar, 2 invisible), 184 guests, and 22 robots.
Key: Admin, Global Mod, Mod
Newest Members
68Spartan, GuySeward, johnn76, jake55, RoadsterDude
17,888 Registered Users
Today's Birthdays
woodbutcher
Forum Statistics
Topics57,943
Posts422,320
Members17,888
Most Online1,133
Jan 22nd, 2020
