Hi all,
I recently pulled my differential from my '20 490 since I had some sideways movement (~1/16" each direction) when I pushed and pulled on the wheels when it was up on stands. I suspected the thrust washer was shot - and was right when I got it apart - see picture (3 pieces). The new bronze one from a Model T supplier fits perfectly. I added additional .030" shims (also from Model T supplier) to close up the remaining gap in lateral movement.
Also, while the car is a '20, I cannot definitively say the rear axle is the original. The ring and pinion are bevel cut in mine. As I understand, the bevel cut wasn't introduced until '22 in original assemblies, but there were replacements of the straight cut with bevel cut available as service items.
Anyway, the question I have is the stamped numbers found on the mounting surface on the axle housings where the torque tube mounts. In this case, its stamped with a 576 on both halves of the axle housings. You'd never see these unless you pull the torque tube off.
Does anyone know what these numbers mean?
The numbers on both side of the rear axle housing would be to ensure both halves that were machined together are assembled together and not mixed up during the further assembly processes.
JACK
Support The VCCA!
Member Photos
My Beautiful 35
My Beautiful 35
by Lorenzo, March 26
1948 woodie
1948 woodie
by firecars, March 7
1918 D5 V8 pictures
1918 D5 V8 pictures
by Mel1940, November 18
Progression on the 64 Impala SS 409
by DreamChevy, October 21
Who's Online Now
1 members (dougs), 190 guests, and 21 robots.
Key: Admin, Global Mod, Mod
Newest Members
GuySeward, johnn76, jake55, RoadsterDude, 46CoupeJess
17,887 Registered Users
Today's Birthdays
woodbutcher
Forum Statistics
Topics57,943
Posts422,318
Members17,888
Most Online1,133
Jan 22nd, 2020
