Click on Use Full Editor. Below the text box you'll see the Attachment Manager. Click on that and follow the instructions. There are size limits so if your pictures are too large they'll need to be resized. Once you select a picture you need to wait for it to appear as a thumbnail in the Attachment Manager window before clicking on Done.
One quirk of the Attachment Manager is that if you want a caption with the photo, you MUST type in the caption BEFORE you add the photo.
After the photo is added to the Attachment Manager, you cannot edit it or add a caption. You can delete it, add a caption, and add the photo again if you want.
