DSVW Offline OP
Hi,
I have a 1956 Bel air with a 6 cylinder and an automatic transmission.
My engine block # is 3837004 which I am told is a 1955-57 6 cylinder block.
The distributor that I have in the car is a Delco that is stamped 1112396-4H02
I was told on another website that it is the wrong distributor for my car and that the distributor I have is out of a 1954 6 cylinder automatic. I was also told it could do potential damage to the gears in my engine and that I needed a 1956-1962 Delco part# 1112 403 distributor instead.
When I called a well-known parts supplier, they told me that I currently have the proper distributor in my car, part# 1112396
Any thoughts?
Wilwood Engineering1955-1957
.your block is for a 1956 or 1957....not a 1955.
The distributor you have is fine for your car , All 1954 Power Glide engines used a cast iron camshaft (early sticks had steel and late had castiron) so the distributor you have has a drive gear that is OK for you cast iron camshaft.
If you have the wrong combination the worst that could happen is after many, many miles the DISTRIBUTOR GEAR could wear out.
DSVW Offline OP
Thanks, Gene. You are always a big help.
Support The VCCA!
Member Photos
My Beautiful 35
My Beautiful 35
by Lorenzo, March 26
1948 woodie
1948 woodie
by firecars, March 7
1918 D5 V8 pictures
1918 D5 V8 pictures
by Mel1940, November 18
Progression on the 64 Impala SS 409
by DreamChevy, October 21
Who's Online Now
4 members (Mike McCagh, ruscar, minetto, 1 invisible), 201 guests, and 22 robots.
Key: Admin, Global Mod, Mod
Newest Members
68Spartan, GuySeward, johnn76, jake55, RoadsterDude
17,888 Registered Users
Today's Birthdays
woodbutcher
Forum Statistics
Topics57,943
Posts422,320
Members17,888
Most Online1,133
Jan 22nd, 2020
