WI_Jeff Offline OP
Hello again to all. Been in a funk for over a year and now trying to get back into my 50 Styleline. I converted to 12 volts and upgraded from the 216 to a 235 engine (from a '56). I have the PerTronix electronic ignition kit and I think it bit the dust. Checked out a few places and cannot find anyone besides PerTronix who makes an electronic ignition kit for a 12 volt, straight 6 Chevy. Does anyone know where and what to get that would be better than the PerTronix?
The darn thing idles great, but when I put any load it starts to miss and die out. New plugs, rebuilt carb and new fuel tank and lines. Open for any suggestions. Thanks to all... Jeff
I would suggest that you put the points back in and see if it solves the problem. If it does throw away the Petronix and use the dependal ighnition system your car was born with.
As far as the coil is concerned the car will run the same with either a 6 volt or 12 volt coil.,,,,,if the coil is good.
... Jeff
Better than the pertronix?
What? Points and condenser
Where? Just about any parts store.
Just check the country of origin, and stay away from those made in China.
Jon
