Hi, I have a 1968 Grumman step van. when I ask for wheel bearing parts I get the wrong parts. On the front I need the inner bearings and races. C30 bearings fit the hubs, but don't leave enough room for the grease seal. The cup, or race, is 3/4" tall and I need them to be about 5/8 or so. What is the correct bearing and cup for this hub, or how can I find out which bearing set I need?
Thank you
Become a Member!
Sometimes it's necessary to remove the old parts and take them to the parts house with you. They should have part numbers on them that can be cross referenced. You may need to contact a bearing specialty company. Around here we go to BRC Bearing in Wichita.
