Posts: 28 |
Are the front and rear fenders on a 1/2 ton and 3/41946 pick up the same? I learned the hard way that the running boards are longer on the 3/4, which makes complete sense if I had thought about it for 5 minutes.
Thank you!!!
Posts: 1,139 Likes: 75
Posts: 1,139 Likes: 75 |
My parts book says YES. Front fenders were the same for 1/2 and 3/4 ton trucks from 1941 to 1946. Rear fender part numbers list the same fender for 1/2 and 3/4 ton trucks from 1939 to 1946.
Hope that helps! :-)
Ole S Olson
Posts: 28 |
Very much!! Thank you. Now, to find the unicorn.
