Plugs & Wires
-- Remove, Inspect & Check
-- Regap Plugs to .040" [AC Delco C-86 Plugs]
Points, Distributor Cap, Rotor, Coil, Condensor
-- Inspect & Check
-- Set Point Gap to .018" per recommendation
Valves COLD SET
-- Inspect & Check w/ Engine Cold
-- Check Each Cylinder & both Valves on Each Cylinder when that Cylinder is TDC (Under Compression Stroke, when both valves are CLOSED)
---- Set Intake Clearance to .006"
---- Set Exhaust Clearance to .008"
Test Fire Engine/ Warm-Up
-- Fire Up Engine (Cross Fingers for Starting Up & Running)
-- Set Timing
Timing
-- Check & Set to 18 deg (Per Recommendations on Here)
-- Warm-Up to Operating Temperature
-- Shut Down Engine & Check/ Set Valves at Temperature
Valves HOT SET
-- Inspect & Check w/ Engine Warmed up
