Posts: 136 |
Hi,
I have a 1956 Bel air 4 door.
I think the rear springs are original to the car, and they are sagging.
What springs would you recommend for this application? The springs in there now are 4 leaf springs. Was that original to the car? Would 5 leaf springs be a better and safer bet?
Thanks.
Posts: 29,204 Likes: 26
Posts: 29,204 Likes: 26 |
The five leaf replacements will make for a stiffer ride and set the rear end up higher. If it were mine I would stay with the four leaf as the newer replacements do not tend to sag as much.
Posts: 136 |
Ok, thanks. Just curious, are the 5 leaf springs a dangerously stiff ride? I don't want the 5 leaf springs to make the rear look ridiculously high....is that the case in your opinion?
Posts: 2,922 Likes: 23
Posts: 2,922 Likes: 23 |
Spring rate (stiffness) is different that load capacity and height.
If everything else (spring length, leaf width and thickness) is the same a 5 leaf spring will be about 20 to 25% stiffer than a 4 leaf. The 5 leaf spring can be designed and built to give the same unloaded ride height as the 4 leaf. Under the same load the 5 leaf will not settle as much.
Posts: 2,542 |
see if there is a spring shop in your locale that can re-arch your original springs. there is a shop in Frostburg, Md that I've used in the past, successfully. mike mccagh
I had the springs on my '57 Nomad rearched,,,,lasated one year and I replaced them with new and 12 years later still good.
Posts: 6,934 Likes: 1
Posts: 6,934 Likes: 1 |
I had the springs from my 32 re-arched 22 years ago and after 12 thousand miles they are still fine. I think much depends on the ability of the shop doing the work and the condition of the springs to start with.
There are no members with birthdays on this day. |
Forums67
Topics56,375
Posts413,508
Members17,512
