. From Doug Bell's "Early Chevrolet History": Bore = 3-11/16", Stroke = 4", 171 Cu In displacement. Front main = 2-3/4 X 1-1/2", Center main = 2" X 1-31/32, rear = 3-1/8 X 2", Con Rods = 2-1/8 X 1-1/2, Cam bearings: Front = 2-9/16 X 1-5/16, Center = 2" X 1-11/16, Rear = 1-7/8 X 1-1/4. All Valves = 1-1/2". . . I hope this halps, Lou .
My block is at the machine shop. While I am waiting for that, I have been working on some of the external engine. I’ve decided to record my progress on YouTube. Check out my video on my distributor rebuild. Let me know what you think. Thanks Jim
Hi everyone. I’m still waiting for the block to come back from the machine shop. I have been working on some of the smaller engine parts. Here is a video of me testing the oil pump. Let me know what you think, either here or on YouTube. Thanks.
Just FYI, one of my two junk yard motor blocks had signs of being froze sometime in its 93 year past. It could be repaired for about $600 but I had another that checked good. Have your guy crack check and pressure test the block. Also one rod is 9 grams out of balance so we are trying another. Thanks for that Rustoholic. Phish
I’m still waiting for the machine shop to finish my block. Is it normal for a shop to take months to bore out 4 cylinders? At any rate, progress on my project has been good. Here is my latest video. It goes over the generator. Enjoy.
I don't know if there is a right way and wrong way to put in the packing. I chose to put it in the nut before assembling the water pump.
I put the nut on loosely so as not to drag too much. Later, when I finally fired up Lurch's engine, it leaked a little so at that point I only tightened the nut enough to stop the leaking. After driving around a while, the pump started leaking again so I tightened up the nut a little more and that took care of it.
One thing that you did not mention in your video was whether you drilled a hole in the front bushing so that oil from the little reservoir can drip down and lubricate the pump shaft as it spins in that front bushing. Every time I go for a drive, I pull the dipstick out of the engine, DO NOT wipe off the end of the stick, and let a couple of drops of engine oil (10W-30) drip into that oil reservoir that is under the fan pulley of the water pump.
Here's a link to the part of my engine build where I show the hole in the front bushing and also how I put the packing in: Rebuilding a '28 water pump for Lurch
Dean, I responded to your comment on YouTube, but thought I should respond here too, incase some one is following this thread. I did not drill a hole in the front bushing because the original did not have one. But now that you mention it, it seems like a good idea. I need to flip the fan mounting plate; so I will will drill it when I take that part off as well as the pulley.
I have a question. When putting the bottom flywheel cover on, is a gasket necessary? Thanks Jim
As long as you use a sintered bronze bearing (Oilite) or equivalent there is no need to drill the hole. Yes I know we commonly call them bushings but technically they are bearings. Any oil added to the depression will seep through the passages to the shaft/bearing (bushing) interface. If you use put a drop or two of oil on the shaft at the bearing everytime you check the engine oil level (at least daily) then there is no need to put oil in the depression.
I made my comment about drilling the hole in the front bearing based on my belief that the replacement bearing in the rebuild kit that I used in Lurch's rebuild was brass.
I just called the Filling Station and confirmed that the bearings in rebuild kits they sell for these water pumps are made from brass. They said that bronze bearings are not available from their supplier of the rebuild kits.
Soooo, ya gotta drill the hole to enable oil to lubricate the front bearing.
Good discussion.
Ever onward, Dean
Thanks guys for the information. It is very helpful and I will try to mention it in my next video. I’m sure others will find it helpful as well. What about the bottom flywheel cover, should I use a gasket?
