Posts: 13 |
Can a volt gauge directly replace an Amp gauge, or do you have to have different wiring? Any replies appreciated
BUD40
Posts: 11,162 |
the usual wireing of an amp gauge is for the guage to be wired in series with the main supply from the generator(+M-) to the battery and a volt meter will be wired in parallel from the (+ M ground) other words the current must go thru the meter to the battery with an amp meter and thru the meter to ground with a volt meter. some amp meters are wired by having the insulated wire going thru a pickup loop at the back of the ampmeter without having a terminal connection.
