Posts: 43 |
Howdy all, I narrowed it down to coolant coming out of tail pipe on my `64 ,283". Car runs great, idles good, not missing how do I narrow it down to a head gasket or intake manifold gasket? Thanks for all your help ! PS , I tried block seal with no results.
you need a cooling system pressure tester.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
In most cases if it is coolant liquid out the exhaust the common cause is a crack in the exhaust port of the head. If a leak (or humid intake air) on the intake side or head gasket generally shows as steam out the exhaust. As Gene suggested pressure tester will give you a good indication though the crack may not open with a cold engine. Tony
Posts: 43 |
Thanks All, will buy cooling system pressure tester
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
You can borrow one from your local auto parts store such as O’Reilly’s, AutoZone, and Advance.
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Just a thought, are we sure it's coolant instead of plain old condensation?
I still suspect tha he has a muffler full of condensation and a good 10 mile of driving will blow it out.
Posts: 43 |
Thanks all, drove around, then out down for 5 minutes & coolant (green) came out tailpipe, did a couple series of run then shut down & every time I started motor up green coolant spit out, funny tho, the car runs great.
Posts: 1,884 Likes: 12
Posts: 1,884 Likes: 12 |
It'll run great until the Coolant hits the Top of the Hot Piston!
Jon T.
Posts: 43 |
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I would be looking at the plug. One of them will look very different, maybe very clean looking. Then you may see signs of coolant leaking from the exhaust to head junction.
If what is coming out of the tail pipe is water it will evaporate quickly. If coolant and it contans antifreeze it will evaporate in hours if at all.
If 1 spark plug is different color to the rest it generally indicates water entering the combustion process. When all plugs look the same and there is a large amount of coolant at the tail end I would be suspecting the head is cracked into the exhaust port. I have heard it can be fixed but never seen a repair last very long. You will probably notice the radiator level dropping as well. Tony
