Another suggestion - have a good look into the interior of the light socket itself. These things were a real mickey-mouse design in that the least little bit of foreign material or corrosion down in there will make the bulb do funny things, like not work, flicker, go on but dim, work great one day and do nothing the next etc. After sitting all winter, each spring I would take a piece of fine sandpaper wrapped around a small dowel and sand the inside of all sockets, then lightly sand the metal exterior of each bulb, and reinstall everything. No more light problems!!
